.....do I need? I've got e609 which I like for front of cab on the speaker grill placement. BUT, I'd like to get another mic for the back of my open back cabs. SO, first - which mic should I get? Second - placement - any suggestions wold be great! Third - I need to get two mics into my computer at the same time and the only option I have is a USB port input. SO, I need some kind of USB interface, am I right? If so - what do I need?
I'd like to start getting some clips up of the RV50 through the open back 2x12 - and some Stingray clips too. Any help would be great! Thanks.
Okay recording/microphone, cab micing geniuses, which mic...
As for what mic you need to run in the back, you'll need a mic with a phase inverter function. You will have phase problems if you are using two mics on one sound source and facing them at each other.
In terms of placement, I'd say just off the cone, about a inch off the cloth. Spend the time to test mic positions and mark your cab.
And to get your mics into your PC, you'll need an A to D converter. I'm not familiar with brands, but that's what you're looking for.
G&L Bluesboy Semi-Hollow > Vox Volume > Boss TU-2 > Fulltone Fatboost (v.1) > Keeley Fuzz Head > Fulltone Fulldrive 2 > Boss DD-5 > EHX Pulsar Trem > EHX Holy Grail > Orange AD30HTC > Avatar 2x12
Multi mics would be overkill for this application.
Get one nice mic The e609 or the e906(better) or a large Diaphram condenser (you'll need a mini mixer and phantom power). A good mic stand is essential. Location of the speaker cab can make a difference in all but very close mic conditions. Put your mic on the boom and have a friend move it about the cab whilst you play and monitor on your enclosed earphones. That way you will hear the best tone and then place the stand to get that, it could be across the cone or in the back of the cab or in the middle of the room pointing at a mirror or wherever, when it sounds right to you, that right.
many of the best recordings from the 1950s and 60s were done this way and its the best way to learn how significant mic placement is in the tone. You can't always do it live because of spill and general noise interference but in recording - wow!
HTH
HTH
Here we go; three, four...
Users browsing this forum: No registered users and 193 guests
