Best way to run ALOT of pedals?
- Orange Expert
In one of my bands I run quite a few pedals (usually around 15, no less than 12) and there is definitely a loss of high end at the end of the chain. I have zero knowledge about effects loops and the like, and this is probably the first time I've really tried to pay attention to signal degradation. I try to keep my cables as short as possible and I run a clean boost at the end to juice the signal back up a bit. Is that moving in the right direction? Would an amp with an effects loop clear this problem up? I can't afford to run less pedals for this, but I need a very pristine clear clean still. Any suggestions are appreciated!
I'd make sure the first pedal you have in your chain is NOT a true bypass pedal, but has a really nice buffer (as in, when the pedal is off, it's still buffering/boosting the signal). That will help out with a lot of issues down the line. Boosting the end of the signal chain won't replace the lost stuff from the front of the chain.
Maybe something like that...
http://www.carlmartin.com/manual%20octaswitch.htm
or...
http://www.pedalboards.com/true%20bypass.htm
or...
Quality patch cables can make a world of difference. I was made a believer when i decided to upgrade my patch cables. I was running somewhere between 15 and 18 pedals on my board, and I just couldn't stand how things were starting to sound. Good quality patch cables really brought everything back to life. Also, if by any chance you have a whammy 4 on your board, throw it behind a true bypass loop. Those things suck tone like no ones business. Just thought I'd throw that out there as your running a ton of effects and it could very well be one of them.
Bad Cat Hot Cat 30
Bad Cat 2x12
Jazzmaster, Telecaster, Stratocaster
Korg Pitchblack , MXR EVH Phase 90, Creation Audio mk 4.23 boost, Danelectro CC Fuzz, Ibanez de-7, boss cs-3, boss dc-2, Dr. Scientist Reverberator, TC Nova Delay
Bad Cat 2x12
Neil's got some good advice - you want to move that clean booster to the front end of the chain or put a buffering pedal in first. The clean boost isn't much good there anyway as all it is doing is boosting the diminished signal.
A buffer pedal is basically something that is high input impedance, low output impedance - an old school Boss pedal would be OK (although they have their own problems), but as I said, a lot of pedals would do the job. I use my Blackstone Mosfet.
Well done on the short cables runs - good idea. Also use good quality cable rather than the cheap moulded patch cable multipacks you get.
Another idea - use a true bypass looper to take pedals out of the signal path that you don't use very often. Eg. I have my wah, chorus, flanger, trem and a 2nd delay in a loop that doesn't get used too often.
Finally, use your amp EQ to adjust for any loss of tone until you get your desired sound back whilst running through the effects.
I also run through about 10 effects, and tend not to have any trouble these days.
<blockquote id="quote"><font size="2" face="Verdana" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by BrianGT</i>
<br />The best way to run a lot of pedals is to run them in to a ...............skip!! Jeese!
Do you get any guitar signal going in to the amp?
Oh - Bendman made a funny! Super Hero of tone - AND comedy! [:p]
I run a number of pedals too (from 10-14 usually). I have a whammy IV and I have no tone loss. How? I start my chain with a SHO after the Korg PB tuner. It give a nice 5 meg impedance boost. Keeps the signal stong and clean until it hits the Whammy. Seems to help a lot. I also run a Sex Drive right before the Whammy (has a nice buffer in it). Maybe that is helping too.
I also run a good number of pedals (3-6 time based/modulation stuff) into the effects loop. Keeping them out of the chain in front I think helps some - but I don't think it's critical to have a loop. I frequently run all of the pedals out front in amps that have no loops with virtually no tone loss (that I could detect).
I think it's more important to have a some boosters and buffers in the chain than to have an amp with an effects loop. Find ones that will work for you. I found that having all true bypass pedals really didn't help. The signal really cleared up when I started adding pedals with buffers and boosts. My two cents.
Greg
Although it's handy if your old wahs suck tone... I got my Vox wah bypassed. Pretty handy for that.
Shouldn't be a problem if the pedal is well designed. I have a mix of both these days... no problems here.
Are you running a Boss TU-2? Aren't those buffered guys? I run my tuner first in the chain. Maybe that would solve it?
I my opinion the Best way to run alot of pedals is
NOT to run alot of pedals! Why mask your tone?
I find a tuner and 2-3 pedals at a time more than enough.
I just take the pedals I know I will use for that evenings
gig, show or jam session.
But that's me...just the guitar and amp is more than enough
almost always, I view pedals as added baggage that just get in
the way of what your true tone should be....
I still own a ton of pedals, but am using them less and less and less.
This would be a normal setup for me these days, less a tuner...at home.
as the lone guitar in my band, I like to expand and sweeten my tonal palette with delay, chorus, wah, and a few other tasty effects
I've A/B'd with no pedals, 3 or 4 pedals and my full pedalboard - hardly any tone change at all - and that's playing alone
with my band, there's no discernable difference at all
my "true tone" is what you hear when I play
(and first in line after my wireless is a Boss TU-2 - maybe that's what helps)
Users browsing this forum: No registered users and 353 guests
