I just might be Orange again.......
brians first post!
seems he had an rv100!....
he also said "If they bring it out in a combo I'm having one"...
Will.
I'll give you it in bite size chunks as I am only just getting to know it!
Firstly....when I fired it up I was really disapointed. It sounded very hard and brittle ....I was kind of gutted because it was probably going to be this or the Supersonic as a different giggable flavour from my Matamp.
Then I had a bright idea![:0]
I'd never seen anyone play it in the shop and so the speakers must be virtually unplayed. So I linked two Matamp cabs together for 8ohms and swapped the internal speaker in to the 8ohm so I could run them at the same time. Both cabs are loaded with very broken in Celestion Century Vintages.
I am playing it with my 59 LP copy in my sig. I have to be able to get a great clean sound with humbuckers or it goes back!! That's more important to me than the overdrive..and I've read so many complaints about the clean sound on here.
I was sure I could get a good clean sound with my Tele or Strat but the LP is the decider.
HUGE difference. I mean HUGE! Instant change of tone. Warm and clear and very chimey.
AS much as I resisted I started to smile.....
The clean channel tone controls obviously interact to alter the mid.....I think I have the bass on around 6/7 and treble on around 7/8....not sure sat here typing but it is a really clean and clear sound. Very like my Matamp actually! I mean it's closer to my Matamp than a Fender or Marshall.
If you do the normal "Fender thing" and have bass on around 3 and treble on about 5 then the mid is pronounced and it's a bit muddy....but increase those tone controls and the mid cleans up.
I tried the effects loop with my CC delay and it works fine. Haven't really listened for tone sucking yet but it seems to be quiet......I can't use the CC in my Matamp because there is an awful earth loop thingy...but it's fine in the RV.
So far so good..and I know I can improve the clean channel....
<blockquote id="quote"><font size="2" face="Verdana" id="quote">quote:<hr height="1" noshade id="quote">seems he had an rv100!....
Yes I did! It sounded great but there was something about the clean sound that I couldn't totally live with....maybe I hadn't twigged the interactiveness of the tone controls!
<blockquote id="quote"><font size="2" face="Verdana" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by BrianGT</i>
<br /><blockquote id="quote"><font size="2" face="Verdana" id="quote">quote:<hr height="1" noshade id="quote">Is it yours or did you abscond it!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If it behaves like a good boy tonight it just might be mine![:0]
bEtter bring a full complement of Harnesses, Straps, Tethers, and the like!:?:
Jimy...HM#5
<blockquote id="quote"><font size="2" face="Verdana" id="quote">quote:<hr height="1" noshade id="quote">If it behaves like a good boy tonight it just might be mine!
So far so good!
She's screaming like a banshee!
I'll say this......it's bloody loud! My ears are ringing![:0]
So far so good!
RV50=best amp ever!
<blockquote id="quote"><font size="2" face="Verdana" id="quote">quote:<hr height="1" noshade id="quote">RV50=best amp ever!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I might never admit to that but it's bloody good!
Jeff...I don't use a lot of gain. There is a sweet spot around 11 oclock where the second stage gain kicks in....with the master on about 8 it is still very open and crunchy. Once I go beyond that compression starts as well as the gain increasing.
I would love to widen that spot up a bit...have you tried any lower gain valves in the dirty channel?
So far I'm impressed....and it blows away the Supersonic! The clean channel has actually surprised me...once you understand the eq..nice and chimey even with a LP!
That's cool!:)
That's cool!:)
Nah, I've only put back EH tubes and biased the power amp just like the ones I replaced (well, as close as I could get, it's crazy the variance on a 'matched' set of tubes). Depending on the music I vary the gain from 1100-0200. The amp really opens up and comes into it's own w/ the volume in the 1100+ range.
Users browsing this forum: No registered users and 387 guests
