SHOW YER STACK! version 2.0
What's the purpose of the p/u covers there? Purely cosmetic, or do they help in the shielding?
Just wanted to keep this thread alive.
http://www.dotphoto.com/GuestViewImage. ... 141&IPP=24
These are maybe some of the better links i found.. if i get better ones, ill post asap.
Im using the AD200 MK3 with 410 and 115. The 15 is at the top right now.
If anyone wants to teach me how to post pics for easier viewing.. lemme know.
www.myspace.com/lastweek<b></b>
OBC115/OBC410/Fender Jazz 04/Fender Jazz '78
1 thing im confused about a little bit... I see you plugged in the 4x10 cab into the 1x15.. then ran it into the 8 ohm jack it looks like.. is that OK to do??? I always was under the impression that you had to plug one cab into the 8 ohm jack.. and if you had 2 cabs.. you split the load by connecting them up to the 4 ohm jacks... someone help me out!
Funny how Oranges stick out like a sore thumb! Nice pics
<b><font size="1">EX-Resident village idiot</font id="size1"></b>
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">1 thing im confused about a little bit... I see you plugged in the 4x10 cab into the 1x15.. then ran it into the 8 ohm jack it looks like.. is that OK to do??? I always was under the impression that you had to plug one cab into the 8 ohm jack.. and if you had 2 cabs.. you split the load by connecting them up to the 4 ohm jacks... someone help me out!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> You can also run them 'daisy chained' which means the cabs are electrically connected in parallel - just as they would be connecting each one seperately to the parallel connections on the 4 ohm output. But you're not wrong to wonder, because...
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The 15 says its an 8 ohm cab. so i have the amp connected from the 8 ohm output to the 15 (8ohm) to the 410. The 410 inputs arent marked as anything specific.
Please correct me if i am wrong.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">The Orange 410 should be an 8 ohm cab too. Running the two in parallel (as you are by daisy chaining them) will give a total load of 4 ohms, so you really should be plugging into a 4 ohm amp output as Ceddy was thinking.
It's always best to match impedances properly with valve amps. But at least if you are going to mis-match you are better doing it the way you did, with the load being lower then the output you used. Rather then having a higher impedance load then the amp output you are using. So you shouldn't have done any damage, but you will be safer using the 4 ohm out in the future. The amp will probably sound a little tighter, and you'll not wear out your power valves as fast
Well spotted Ceddy. Good call!
Good guide to the whole impedance thing:
http://ebassist.com/vb3/showthread.php?t=11117
AD30HTC x 2x12 cab
Gibby Explorer (SD Pearly Gate set)
Fender Jeff Beck Strat w/full size JB Hum in bridge
PRS Custom 24
Modded TS-9 & DS-1
www.electricharmony.net
PRS Custom 24
Modded TS-9 & DS-1
Users browsing this forum: No registered users and 395 guests
