Cheapest way to sound proof?
hey so the LAPD has explained to me that i play my music too loud. three times.
i have no clue how to soundproof, and i probably don't have the cash because i'm sure its expensive.
anyone have any luck with cheap soundproofing?
My name is Alex. I used to have an AD30HTC, but now I have an RV50 and PPC212.
Buy a pignose .
Seriously, baffles are pricey. Maybe you can hang rugs up everywhere? Guys?
my friend soundproofed his room. he used a fuzzy carpet material and just covered the walls. it looked really nice too. but i am no help as to what the carpet stuff was. but maybe you should go out and find some nice carpet and line your walls with it.
-tim
fender double fat strat through:
TT-->BYOc tri-boost-->avatar 1x12 w/ greenback.
fender deluxe 'verb.
If you want a room that's significantly quieter, there's no cheap way to do it. Sound is like water--it finds the "low spots" and comes rushing out. So you have to try to eliminate all the ways that the sound can get out of the room. This is never cheap.
Sure you can do stuff like nailing egg crates or carpet up on the walls and ceiling (and floor) may help a little, but that won't have much of a <i>soundproofing</i> effect, unless you can do layer upon layer upon layer (it'll cut down on reflections within the room though)...and even then...this kind of thing won't necessarily keep the sound from traveling out of the room.
Something's better than nothing, I suspose...but is it enough better? I'm sure the cops will let you know if it isn't...
don't let these idiots tell you to 'turn it down', or 'play softer' - pussies! - you probably heard that enough from your parents
this will help:
http://www.soundproofing101.com/
this will help:
Max Prophet stole all my thunder! I was gonna suggest buying them earplugs too....
-Joe
Hmm thats a bad situation. Whenever we can't use the studio we just go to one of our houses and the drummer uses brushes and we all turn down. I find it really helps sometimes as it allows you all to hear everything better and make sure you're tight. Of course you can't really rock out but hey, compromise. Isn't there a practice room nearby that you could rent for a few hours a week or whatever?
Josh
can't soundproof properly w/o building a floating room inside a room.
It's unlikely your drummer can play softer (bloody leadfoot drummers).
Playing w/ brushes helps, but sounds like you've gotta find yourself a JAM SPACE
Orange AD30HTC w/ PPC112 + other home made cabs, and pedals
'73 Guild S-100 - '78 Ibanez LP
Users browsing this forum: Google [Bot] and 258 guests
