Is this a mis-print?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hamfist</i>
<br />For accuracy, I will mention that the RV50 has 4 x 6V6's not two.
yea that too...
yea that too...
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PopnFresh</i>
<br />Erm isnt this because the 30 is class A, the 50 class A/B?
good point !!!:oops:
+1.
6V6 = best tube on the world IMO.
+1.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Borderline Productions</i>
The 6V6s are found only in a few amps.
And those are typically great ones....
Jimy...HM#5
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by 77custom</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PopnFresh</i>
Nope, the Rocker 30 isn't class A, it's A/B as it's got a phase inverter tube in it, thus the power tubes are in push pull config.
<br />That seems wierd to me because the R30 uses EL34's (25 watts <b>max</b> disapation per tube)for 30 watts and 6V6's in the RV50 for 50 watts(12 watts <b>max</b> disapation per tube which equals 50 watts).
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Those are <b>maxima</b>. Whether an amp will ever use that potential depends on a lot of other things than just the valves. Like the whole power amp circuit design basically. But you can run the valves at any power below that maximum you like!
http://www.thegearpage.net/board/showth ... p?t=149025
The orange site states that the <b>Reverbrocker 50</b> has 2 6V6 for the output tubes.
Was <i>that</i> a mis-print? [:p]
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Neiloler</i>
<br />Nope, the Rocker 30 isn't class A, it's A/B as it's got a phase inverter tube in it, thus the power tubes are in push pull config.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">The R.30 isn't class A, true enough. But that hasn't anything to do with it being a push pull amp. You <i>can</i> get push pull class A amps...
http://forum.orangeamps.com/viewtopic.p ... d,parallel
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Andy H.</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Neiloler</i>
Yeah, isnt it a push pull amp that has been biased to be class a to give it lots of nice crossover distorion, or is my brain failing me?
Users browsing this forum: No registered users and 190 guests
