I just transported my rocker50 and the "on" light doesn't turn on now.
The light looks ok, the filament looks good.
If it is not the lightbulb (whick i will try to replace), what should i do?
thank you
Rocker50 Lights OUT!!!
Does the amp come on?
My name is Scott. This is my other forum. http://bluesguitar.forumcircle.com" onclick="window.open(this.href);return false;
This happened to my Mesa a while ago. Then, after retolexing it it magically started working again! I think there might have been something loose that was put back in place after i'd taken it all apart and put it back together.
Most online guitar part stores will stock the bulb you need. I'd try a new bulb and if it isn't that and you really want the light to come on take it to a tech. It should be a quick and easy fix.
Josh
Users browsing this forum: No registered users and 426 guests
