SLAVE OUTPUT AT THE BACK OF OR 120
The slave out is designed so that you may use the preamp section with another power amp. Say you need to drive 4 cabinets. Just use the outputs on your amp for two and get an Orange slave amp to drive the other two. I have used the slave out for direct into the sound board recordings as well...but you should have a speaker load on the outputs when the amp is on so you don't blow the output transformer.
Users browsing this forum: No registered users and 417 guests
