How is it that....
an AD140 produces 140 watts from 4 EL34's and the RV100 produces 100 watts from 4 EL34's? Considering tubes have to be biased so they are running a certain voltage, I would think that any given combination of tubes would produce the same output in any amp. Also, my AD140, while it is very loud, doesn't seem as loud as you would think a 140 watt all tube amp would be.
PRS Custom 24
American Vintage 62 Jazzmaster
Orange AD140
Orange PPC 412
http://www.myspace.com/brianellismusic" onclick="window.open(this.href);return false;
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by airforce_brian</i>
<br />an AD140 produces 140 watts from 4 EL34's and the RV100 produces 100 watts from 4 EL34's? Considering tubes have to be biased so they are running a certain voltage, I would think that any given combination of tubes would produce the same output in any amp. Also, my AD140, while it is very loud, doesn't seem as loud as you would think a 140 watt all tube amp would be.
I may be wrong, but I believe difference in wattage has something to do with the size of the Transformers.
Secondly, the perceived loudness of my RV100, to me, is less than every other 100+ watter I've owned. Still F'N loud though!:D[:0]
((((((((((((((((((((((((Andy))))))))))))))))))))
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by neonrust</i>
<br />
I think orange amps are just quieter in general than some other amps. My singers 50 watt vox seems as loud as my AD140.
<br />
PRS Custom 24
Orange AD140
Orange PPC 412
<br />
I think so too, but I'll take tone over shear volume any day.:D
<br />
<br />
Agreed:D
<br />
Agreed:D
PRS Custom 24
Orange AD140
Orange PPC 412
Its weird, i play an AD30R and i've played it in some really loud situations and never had to have the volume above half way.
I cant imagine how loud an 140 watt valve is and i cant imagine any situation where you could have it turned up anywhere near full without everyone screaming at you.
Most of the venues i've played i get asked by the soundguy to turn down till the volume is on about 3... the facists!! of course i always turn back up once the set starts.
myspace.com/thevivahighrollers
The wattage of the amp is generally determined by the plate voltage fend to the power tubes as well as a whole host of factors. Its likely that the AD140 is probably 100 watts clean and about 140 watts distorted. The RV100 with be similar. To get 140 watts out of a quad of EL34s, each would have to put out 35 watts of power, which is above their max dissapation. Not even an NOS Mule could withstand the plate voltages needed to do that!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rrrajo</i>
<br />Two Rights! 1. Plate voltage 2. Transformers
Transformers dont really affect that power that much...Take the OR80 and OR120. Exact same transformers, same plate voltages, half the wattage
<br />Right! You will have to excuse me for being born in the 60's when half of 120 was still 60.
So the Or80 with 100 watt or better transformers should perform more or less the same as a Rv50 with 50 watt Transformers?
Yes but due to the larger transformer, the tone will be different. Its to do with how the core saturates when the amp is wound right up. I'm not to sure myself. You also get increased head-room i believe with less compression. Vintage Orange transformers were always way over-specced hence their generally loud and clean tones.
Simon,
YOu are right on several counts. The Or80/120 are the same amp minus two tubes. Alot of people use the 3db Rule as illustrating the Difference between Two or Four Output tubes ignoring the respective Outputs. This is a Perfect example. There really would only be a 3db dif between these heads.
However, If you took the OR120 and compared it to say a RV 50 the difference would be greater.
I was tempted to get an Or 120/80 until I Settled for the Stupid Soldano as it were.
I will be on the Lookout for a Retro, AD, or Thunderverb 50 as my next Aquisition.
In any event, I don't believe there will be enough time or money in my Lifetime to Get everything I want.
Jimy...HM#5
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Simon Wicks</i>
<br />The wattage of the amp is generally determined by the plate voltage fend to the power tubes as well as a whole host of factors. Its likely that the AD140 is probably 100 watts clean and about 140 watts distorted. The RV100 with be similar. To get 140 watts out of a quad of EL34s, each would have to put out 35 watts of power, which is above their max dissapation. Not even an NOS Mule could withstand the plate voltages needed to do that!
That makes sense to me. So i guess the 140 watts is almost more of a marketing thing then anything. I'm glad that my amp probably isn't producing 140 clean watts, because that would be way too much! Thanks:D
PRS Custom 24
Orange AD140
Orange PPC 412
Users browsing this forum: No registered users and 393 guests
