Has anyone tried a 12at7 preamp tube dirt ch rocker 15 terror head ?
With my tung sol 12ax7 doing dirty channel duties, even with gain turned way down, it ain't warm, glassy and clean, has anyone tried a 12at7 for dirt channel and did you find it really cleaned things up or not ?
Fender USA Ash Telecaster
Orange Rocker Terror 15 Head
Diamond CPR1 Compressor
TC Electronic Sentry
CAE MC 404 Wah
Catalinbread Talisman Reverb
MXR 234 Analogue Chorus
Naga Viper
Suhr Riot
Zilla 1x12 Cab with Greenback
CAE MC 404 Wah
Naga Viper
Suhr Riot
Re: Has anyone tried a 12at7 preamp tube dirt ch rocker 15 terror head ?
Try a 5751. Not as much gain as a 12AX7, more musical than a 12AT7. You might try different power tubes as well.Old School wrote: ↑Mon Feb 17, 2020 10:50 pmWith my tung sol 12ax7 doing dirty channel duties, even with gain turned way down, it ain't warm, glassy and clean, has anyone tried a 12at7 for dirt channel and did you find it really cleaned things up or not ?
My Rockerverb 100 mk3 has 6 preamp tubes total:
12AX7's: 1 for stages 1&2 clean chan., 1 for stages 1&2 dirty chan., 1 for stages 3&4 dirty, 1 for phase inverter.
12AT7's: 1 for FX loop, 1 for reverb
So I'm assuming they used 12AT7's in those two spots because they are cleaner and less prone to overdrive. So you probably wouldn't want to use one for a dirty channel in an amp unless you're looking to limit the overdrive and clean it up a bit.
Users browsing this forum: No registered users and 248 guests
