Question about electrical stuff idk about
Can I plug an Orange Crush 12, purchased from the US, into an outlet in the Philippines?
Re: Question about electrical stuff idk about
Depends on your voltage. If it’s 120 then yes. If not, the amp needs to be modified if it doesn’t have a voltage switch. From what I see, it’s 220 in Philippines so the general answer is no.
According to the manual you can switch between voltages. You also need to change the fuse:
https://orangeamps.com/wp-content/uploa ... Manual.pdf
Sooner
AD1512 Serial No. 001
Users browsing this forum: No registered users and 184 guests
