Hi, just got a used Rockerverb 50 combo, that has been serviced.
I just love the clean tone, but have issues with my dirty channel. To match the clean i have to turn the master almost full and the drive to. Until 12:00 there is almost no drive at all, and them around 1:00 it opens up, but still really does so if i have a guitar with hot pickups and or booster in front of it.
Is this normal or is it a problem? Should there be almost no drive until 12:00 on the dirty channel gain. Btw have to crank the master to get something that might be called high gain.
Thanks for your help and opinions!
Rockerverb 50 Dirty low volume
Re: Rockerverb 50 Dirty low volume
Hi Esers. Could be a preamp valve failure in that channel. A little simple valve swapping will tell you if that is the problem.
See here for valve functions:
http://forum.orangeamps.com/viewtopic.php?f=3&t=42244" onclick="window.open(this.href);return false;
See also here:
http://forum.orangeamps.com/viewtopic.php?f=3&t=47995" onclick="window.open(this.href);return false;
See also here:
Here's my solution to this problem:
Good you found that.
Users browsing this forum: No registered users and 228 guests
