tiny terror with carvin v412-c
You can not use a 4 ohm speaker with the tiny terror, you can damage your amp in this way.
These are the options you have:
1) 1 8ohm speaker to one of the 8 ohm outputs (you should not connect two 8 ohm speakers to the two of the 8 ohm outputs simultaneously. This can damage your amp)
2) 1 16ohm speaker to the 16 ohm output (you can connect two 16 ohm speakers to the two of the 8 ohm outputs simultaneously)
Hope this helps...
Hope this helps...
Yaron
To clarify what ohmage the cab is, all you need is a digital multimeter.
Stick a speaker cable into your cab. Then measure the resistance in ohms with a DMM between the tip and the sleeve of the other end of the cable. The resistance reading you get should be approx 80% of the actual resistance of the cab in use. SO a 16 ohm cab will measure about 13 ohms, an 8 ohm cab will measure about 6 ohms, and a 4 ohm cab will measure about 3 ohms.
If you do find that the cab is a 4 ohm one, then you will be able to re-wire it inside easily enough to make it a 16 ohm cab.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hamfist</i>
<br />To clarify what ohmage the cab is, all you need is a digital multimeter.
I started to write this same response last night right when the forum went down. What's been wrong with this two-bit internet forum lately?!?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Gladmarr</i>
<br />I started to write this same response last night right when the forum went down. What's been wrong with this two-bit internet forum lately?!?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Probably a valve failure - usually is... [:p]
<br />There shouldn't be much fluctuation when you do the measurement unless there was a faulty contact or a bad lead on your meter. It should have been pretty steady on the readout.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">+1 Better to be sure...
I'd take a look inside the cab, see what impedance the drivers really are and how they are wired. Check too for loose connections that may be causing the fluctuations with your readings - it there are any they may play havoc with your amp!
Wiring diagrams here:
http://www.colomar.com/Shavano/spkr_wiring.html
Thanx for all the info, i rechecked the speaker cab and now im getting a pretty steady 3.4-3.5 ohm, so i guess this is a 4 ohm cab, s---! yeah and this cab is sealed so i would have to remove the front grill then the speaker's from the front, anybody want to trade for a 2-12 orange cab? or even a 1-12? i guess im gonna put this cab aside and pick up a orange 1-12 cab to start soon. Do those go loud enough with just 1-12? Also how do i add a signature to my posts?
Users browsing this forum: No registered users and 16 guests
