Rockerverb for Classic Rock?
Hi All
I will soon be in a position to buy a new rig and am currently torn between Marshall and Orange amps so could do with some advice.
My situation is this, I play in a covers band doing typical pop/rock material from clean to rock, AC DC is the heaviest we go. I use a Fender amp and use pedals for dirt. I play a tele in the first set and switch to a les paul in the second set as it is a rockier set which I play entirely through a RAT. I don't need shed loads of volume as I'm always miced, just need to hear myself against the drummer really.
My big concern about Marshall is the apparent lack of quality in new products compared to Orange. I definately will be buying new so please don't suggest vintage.
Essentially I am looking for two channels, a clean that stays clean against a drummer and a Marshallesque dirt channel. Also a good f/x loop and am looking for head and cab.
As the title suggests I am leaning towards the Mk3 Rockerverb.
Any thoughts?
Nigel.
Any thoughts?
Nigel.
Orange TH30 Head
Orange Rocker 15
2 - 2x12ppc Open back
Orange Rocker 15
Re: Rockerverb for Classic Rock?
.... Uhm, yes.
50mkll with a 212 is almost overkill.... Gain hardly ever goes over 12 and the volume stays around 10:30 ish.I could see the alternator in the mklll being useful. Be weary of the 112, it does not do the head justice.
... Oh, and I play in a semi-pro. rock cover band so for classic rock its just ace!!
The RV sounds ace, but it doesn't really sound like a Marshall.
It will sound warmer, and a bit thicker. In my opinion better, but yours may differ.
I was thinking of the 2x12 openback with a view to having 2 stacked for versatility, the amp I currently gig is a Fender Vibroverb. In the pubs we play there generaly isn't much space so I end up with the amp right by my legs, that kills a lot of volume to my ears so I use the tilt back legs to point it at my head, hence thinking 2 cabs stacked would be great for hearing myself without having to turn up too much. I don't much fancy dragging a 4x12 to practice every week!
Orange TH30 Head
Orange Rocker 15
Orange Rocker 15
How do you two guys feel the RV works with a les paul? Many forums suggest its not a great combination, a bit dark,muddy? Don't shoot me, just passing on other peoples comments. The same people seem to feel that it pairs very well with a tele too.
Orange TH30 Head
Orange Rocker 15
Orange Rocker 15
RV and some 212s (or 1) would be great for what you want to do.
I use various guitars through mine, teles work great. I really like the firebird v with the RV sounds huge but your initial question was a LP. I think they sound awesome, never thought they were muddy.
NB__England wrote:How do you two guys feel the RV works with a les paul? Many forums suggest its not a great combination, a bit dark,muddy? Don't shoot me, just passing on other peoples comments. The same people seem to feel that it pairs very well with a tele too.
Well..... Bear in mind that I have the RV50 MKI, not the MKIII, and I believe they are a hit different on the dirty channel front.
With my Les Paul Standard faded (burstbucker Pro pick ups) it is a bit dark (certainly not muddy) depending on settings.
You can always increase the treble, reduce the bass to suit. Personally, I love the dark, thick grunt of a LP through my Oranges.
There's nothing quite like it!!!
As for the PPC212, you could always buy one only and rest it on its side?
+1Les Paul Lover wrote:Personally, I love the dark, thick grunt of a LP through my Oranges.
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
The thing I noticed first about using an orange is that the pickups used make a big difference. I also find it funny because I have a strat and some gibsons and I really don't like the sound of my strat through my RV MKIII. It just doesn't sound good to my ears.
I haven't heard people say that a les paul through a RV is bad but I guess when you look at the orange forum more than anything, the sample audience tends to be a little skewed.
Rockerverb 100 MKIII
Rockerverb 50 MKIII combo
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson explorer custom
gibson es355
gibson es359
gibson sg custom
gibson les paul custom
gibson les paul standard
gibson les paul studio
gibson melody maker
AD30TC combo
TH30c
Fender Bassman
Fender Princeton
gibson es355
gibson es359
gibson sg custom
gibson melody maker
For classic rock, get an OR50.
If there's no need for Fx loop, the Ad30htc would do well too.
But the RV50 will pull it off just fine really.
The openback is probably a good solution seeing that the CB is verrrrrrryyyy directional. But that is easily solved...Get a case for the 212 and pop it on top for pub gigs or go in-ear if your always miced (your hearing will thank you).NB__England wrote:I was thinking of the 2x12 openback with a view to having 2 stacked for versatility, the amp I currently gig is a Fender Vibroverb. In the pubs we play there generaly isn't much space so I end up with the amp right by my legs, that kills a lot of volume to my ears so I use the tilt back legs to point it at my head, hence thinking 2 cabs stacked would be great for hearing myself without having to turn up too much. I don't much fancy dragging a 4x12 to practice every week!
or just turn it on it´s side if you can stand that the Orange-emblem being a little off...something my OCD has issues with. (Excuse the corny pose....to many Jack and cokes the night before left me feeling a tad silly
Just awesome and nooooo mud, at least not with burstbucker pros (2). Maybe a little modern compared to the mini-pups in my firebird or the pups in my SG, but that might have a little to do with the vintage style Gibson strings I use on those 2?!NB__England wrote:How do you two guys feel the RV works with a les paul? Many forums suggest its not a great combination, a bit dark,muddy? Don't shoot me, just passing on other peoples comments. The same people seem to feel that it pairs very well with a tele too.
My other guitarist is a Fender guy and we´ve tried his through the orange...sounds nice but you may need to mess around with the EQ between switches to get a great sound. When it comes to the Gibsons I only have to alter the gain/volume between guitars. The LP is a beast when it comes to output
Hi welcome to the forum.
Poor Marshall quality and excel Orange tone is what converted me to Orange over ten years ago and I've not looked back ....although have owned numerous Orange amps.
The RV will do a good job of classic rock and is a good choice if you need a pretty clean channel and a dirty channel and an fx lop. There are arguably imo better choices for classic rock although not necessarily with the other features you mention . What about the new rocker 32?
I've used various Orange amps with a les paul, , admittedly the RV mk11 and not the mk111 but 've never thought of it as muddy .
If youre mic'd why lug around big gear, go for an Orange Rocker 32 or a Marshall DSL40C and an amp stand to raise it off the floor. Either would do you fine but if youre looking for Marshall tone then get a Marshall, the DSL40C is a fine piece of gear.NB__England wrote:Hi All
Any thoughts?
Nigel.
I had a Rockerverb MkI 50W for classic rock which delivered great results with or without some boost, OD, etc. Initially I had the 2x12 CB cabinet but as others have said it was a Death Star beam in front of the speakers and virtually nothing outside them...I eventually got an Avatar 4x12 Fender style that breathed and bloomed much more.
Let us not forget the 'Verb' part of the name...Orange reverbs knock modern Marshalls into a cocked hat. A bandmate has a DSL40 combo that he loves for compactness and power but hates the reverb so much he's obliged to use an outboard pedal.
Users browsing this forum: No registered users and 33 guests
