Daisy Chain - 3/4 stack
Tominho
Post by Tominho » Thu Jan 12, 2012 4:22 pm
Long time lurker. First time poster. I've just scored a new orange 412 to go with my 212OB. I'll probably try to move by 212 soon; but in the meantime, I want to daisy chain them for a 3/4 stack.
I have a Tiny Terror and TH30. Both have 1 16 ohm output and 2 8 ohm outputs.
I assume to ensure everything is hooked up right I would go from either amp's 8 ohm output into CAB A's 16 ohm input. I'd then connect a second speaker cable from CAB A's second input into the 16 ohm input on CAB B. This would mean that both cabinets are running at 8ohms and since I've sent from the head's 8 ohm input I'd be ok....
Also, can I run speaker cables from the 2 8 ohm outputs on the head directly into both CAB A + B; thus eliminating the daisy chain?
I'm very new at this, so please forgive my ignorance. All I'm looking for is confirmation that this is correct. Thanks
mr_william
Re: Daisy Chain - 3/4 stack
Post by mr_william » Thu Jan 12, 2012 4:27 pm
that is exactly correct!
8 ohm out to cab 1 then to cab 2, daisy chained.
or
8 ohm out to cab 1 then second 8 ohm out to cab 2, eliminating the daisy chain.
Will.
Tominho
Post by Tominho » Thu Jan 12, 2012 4:34 pm
mr_william wrote:that is exactly correct!
or
Thanks for the quick reply. I wanted to be 100% sure before destroying an amplifier.
I should get my 412 tomorrow and I'm really excited. I think I've seen a 212 on top of a 412 in someone's signature on this forum. It will look killer in my house while I have it.
Another question. How long should it take to break in a 412. I've only played used 412s before. My 212 didn't seem to take that long.
Dark Helmet
Orange Expert
Post by Dark Helmet » Thu Jan 12, 2012 4:44 pm
Tominho wrote: Another question. How long should it take to break in a 412. I've only played used 412s before. My 212 didn't seem to take that long.
it probably takes, what 20 hours of really working the speaker to fully break it in... so, counting potty breaks, about a day.
Dark Lord of the Schwartz
Thunderverb 50
AD30TC
Crush Pix 35LDX
Crush Bass 100
Avatar 412 Contemporary V30/G12Hs
Gibson Les Paul Classic Custom
Gibson Firebird Studio T
Epi Les Paul (not remotely) Standard
Epi Les Paul Custom (SOLD)
AD30HTC (SOLD)
Users browsing this forum: Google [Bot] and 5 guests
